reivt mep
reivt mep
reivt mep
As usual, a few questions about Revit MEP. We work with industry architect (we design Electronics and telecommunications engineering) We get decks (models) of ArchiCAD IFC format. As Revit should set a new layer which will, for example, the same slot. And then just send them a slot. So as to be able to hook up to your model. Another question . To How plotować Revita drawings had to to make sense. It is known , WITH NOT IN 3D . And How to create a table (bottom right corner)
chrisplyler
I apologize, but I am not able to understand most of what you have said. Revit does not have layers.
Once again.
Project gets created in ArchiCAD. I want to apply only the electric elements and return only items without the rest. The architecture will be for me just backing.
"Link" in the Architects Model or Ifc, or whatever, and then create your Electrical objects.  Since the Arch Model is "linked", when you send your Elec Model back to them (or otheres), the Arch model will not travel back with it to them...just YOUR models(s).
M
