"DN50 mmØ" how do I make DN50
SERDAR.CINAR59
SERDAR.CINAR59
I want to give the name and DN50 DN100 codes to my pipes with the pipe tag, but it is "DN50 mmØ", how can I remove this unit at the end? Can you help me?
iainsavage
To get rid of the mm edit the pipe size units:
To get rid of the diameter symbol edit mechanical settings:
mikewp90
the Size parameter is limited and the unit is hard coded in there. THis is because it is used for things like frame size as well which includes WxH.
For pipes use the "diameter' parameter.
Within the pipe tag label, ensure you have the units set to show none.
SERDAR.CINAR59
Yes thank you so much @mikewp90
