Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
"Connect Into" Revit Shortcut doesn't exist for Revit 2026
Sefanja_Verkaik
Message 1 of 8
Sefanja_Verkaik
Does anyone know why the Shortcut for "Connect Into" is removed in Revit 2026?
Or is it renamed? And if so what is the new name for the shortcut? I cannot find it anymore.
Replies (7)
Message 2 of 8
blank...
Yup, I already reported it, forwarded to development team for a fix in update. Update .2 came and went... No shortcut.
Message 3 of 8
blank...
Update .3 came and went... No shortcut.
Message 4 of 8
wlentz5RNA5
Community Visitor
Community Visitor
Any update to this issue? It's messing with my work flow and taking longer to pipe up heads.
Message 5 of 8
rcrdzmmrmnn
I know this is a MEP forum but if it can help anyone this is a sample command in C# that will create a button in a addin tab that will simulate the click on connect into, then you can assign this button to a shortcut command... You will need to understand a bit of revit API and programming but there are plenty of tutorials out there.
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System.Windows.Automation;
namespace RTG.Addin.DISCIPLINAS.HID;
[Transaction(TransactionMode.Manual)]
public class ConnectInto26 : IExternalCommand
	private UIApplication Uiapp;
	private UIDocument Uidoc;
	private Document Doc;
	private View VistaAtiva;
	public Result Execute(ExternalCommandData commandData,ref string message,ElementSet elements)
		Uiapp = commandData.Application;
		Uidoc = Uiapp.ActiveUIDocument;
		Doc = Uidoc.Document;
		VistaAtiva = Doc.ActiveView;
		using (Transaction tx = new(Doc,"Transaction"))
			try
				tx.Start();
				try
					ClickConnectInto(Uiapp);
				catch
				tx.Commit();
				tx.Dispose();
			catch
				tx.RollBack();
		return Result.Succeeded;
	public static bool ClickConnectInto(UIApplication uiapp,int timeoutMs = 3000)
		var hwnd = uiapp.MainWindowHandle;
		if (hwnd == IntPtr.Zero) return false;
		var main = AutomationElement.FromHandle(hwnd);
		if (main == null) return false;
		var t0 = Environment.TickCount;
		while (Environment.TickCount - t0 < timeoutMs)
			var connectBtn = main.FindFirst(
				TreeScope.Descendants,
				new AndCondition(
					new PropertyCondition(AutomationElement.ControlTypeProperty,ControlType.Button),
					new PropertyCondition(AutomationElement.NameProperty,"Connect\r\nInto",PropertyConditionFlags.IgnoreCase)
			if (connectBtn != null)
				if (connectBtn.GetCurrentPattern(InvokePattern.Pattern) is InvokePattern invoke)
					invoke.Invoke();
					return true;
				return false;
			Thread.Sleep(100); // wait a bit and retry
		return false;
Message 6 of 8
Sefanja_Verkaik
Hello and thanks for the Tip,
Personally I will not be able to use this as a solution due to IT restrictions. But I think its a great tip for those who can.
Message 7 of 8
design587TZG
Apparantly fixed in Revit 2027 according to incident
236454 (https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-assign-k...).
Autodesk says "We recommend access the CONNECT INTO command from the Ribbon in Revit 2026.".
I wish they'd fix it with an update to Revit 2026.
Message 8 of 8
Sefanja_Verkaik
Yes it is fixed in Revit 2027, However in Revit 2027 they removed the option to select a large group of pipes and fittings of the same size and change the size. This is an even more "Core" function of MEP modelling. So be cautious with upgrading Revit models to Revit 2027.
Revit 2027 Pipe Options Tab - Autodesk Community
