Quazite Box dimensions
hzieger
Message 1 of 12
hzieger
I need to place a number of quazite boxes and that will be an issue for the future frequently. I am a Real Newby to Revit and I am struggling with getting a rfa set up so that I can change dimensions as needed and can't even find the right family where to place it. I would think it belongs to the Electrical Equipment family but there I can't add the parameter for the depth. That piece I downloaded has only length and width.
Unfortunately, I could not find a manufacturer who has rfa files for their quazite boxes. Maybe a different name is used in Revit for these things?
Many thanks for your help, I am desperate to get that solved.
Replies (11)
Message 2 of 12
L.Maas
They are often called junction boxes or terminal boxes. You might look for those. You also could look at sites like bimobject.com. Those sites have lots of content from different manufacturers
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 12
hzieger
Thanks a lot for the advice. I will definitely check those junction boxes again. What I saw so far yet was that they are all more or less steel boxes for passing through wires, mounted above ground. The boxes I am talking about are buried in-ground, made from concrete and open at the bottom. See the attached link.
https://www.hubbell.com/hubbellpowersystems/en/Products/Power-Utilities/Enclosures---Below-Ground/Bo...
Many thanks again and have a great day
Harald
Message 4 of 12
RSomppi
Have you tried contacting Hubbell? They have 3D drawings. I couldn't find any for these boxes with a quick search but that doesn't mean they don't have them.
For help with your family, upload it.
Message 5 of 12
hzieger
they don't seem to have rfa files. Only AutoCAD.
Message 6 of 12
RSomppi
You can use the .dwgs and spec sheets as references for your family.
Also, keep in mind that not all companies make their families available for on demand downloads. Some require an account or only provide them on request. Contact them. They might be helpful in this aspect.
Message 7 of 12
hzieger
"You can use the .dwgs and spec sheets as references for your family."
Many thanks for the advice. As I mentioned, I am a real newbie and I have no idea how to use a DWG file in Revit. Is there instruction and if so, where can I find it?
Message 8 of 12
hzieger
I did actually call the manufacturer Hubble and they said they don't have any rfa files, only CAD
Message 9 of 12
hzieger
It's Revit 2022
Message 10 of 12
sragan
This video is in a series of videos for Revit Electrical Designers.  It will show you exactly how to make a family that has adjustable depth, width, and height:
Revit for Electrical Design Professional Certification Prep - Understand family creation workflow | ...
Message 11 of 12
hzieger
Great! Tanks for the link. It did help really. I started the curse and I am at section 4. For what reason ever, the dimension parameter I added "depth" is now part of the family, but the value stays at 1" no matter what I do?
Message 12 of 12
stever66
You may have missed a step.   Or you may have locked the depth at 1’ instead of locking the box geometry to the reference planes.  Try selecting the depth dimension in the family editor and seeing if there is a lock symbol you can unlock.
if that doesn’t help, try starting over and following the video again.  It shouldn’t take more than 5 min.
Also, they don’t mention it in the video, but any of these dimensions can be connected to either a “type”  parameter, or a “instance” parameter.   With instance parameters, you can individually adjust the dimensions for every box you place.   Flexible, but it can also be a pain if you need to place a lot of them.
With the type parameters, you make a different family type for each size box you want available.   Then each time you place a box, you just pick the type that is the right size.  This works well because there are probably only 5 or 6 sizes you will use most of the time.   And if you do happen to need an odd size, it’s easy to create a new type on the fly.
if that’s confusing, just google Revit type vs instance parameters or search YouTube.
