Publish to NWC Add-In for Revit 2023 not Functioning
austin_garstYVWLJ
austin_garstYVWLJ
Greetings.
I'm having some issues with the functionality of this add-in on a project in Revit 2023. The button is grayed out. And it says, "Install the Navisworks NWC exporter to enable this functionality." I have it installed, otherwise I shouldn't be able to see the button at all. Even still - when I try to install it, Autodesk Access lets me know that I have it installed already.
Any ideas on how to resolve this?
Thanks.
fabiosato
Just to confirm, this is the page from where you can download the export add-in.
https://www.autodesk.com/products/navisworks/3d-viewers?_ga=2.46138215.1128728288.1621788806-1177203...
Fábio Sato
austin_garstYVWLJ
This is not the add-in I am referring to.
I am referring to this add-in: https://up.autodesk.com/2023/RVT/NPA_1.0_ReleaseNotes_Revit2023.htm
When I try to install it using this installer, the end result says "Add-on is already installed."
fabiosato
To make the export NWC available in Revit, you need to install the plug-in I mentioned. Then, the plug-in you installed should work.
Fábio Sato
austin_garstYVWLJ
Thank you. This worked.
