Properties Palette - Edit Order of Parameters Displayed
Is it possible to re-order the fields displayed in the properties palette-- specifically to re-order the categories of fields? For example, I mainly use the "Identity Data" category of fields when assigning spaces, which is located at the very bottom of the properties palette.
Ideally this category would be located just below the Constraints category.
No, those are hardcoded.
Bummer. Thanks for the quick response ToadDN!
