PROMBLEMS WITH DUCT LOSS CALCULATIONS
juan_escabiasAUZ5J
Observer
juan_escabiasAUZ5J
Observer
Observer
I often encounter this problem with the REVIT duct fitting loss calculation. Only now have I time to try and relay it (using Revit 2024). In the attached PDF I have summarized the extent of the problem with some screen grabs, calculations and tables.
THE PROBLEM: Revit does not seem to calculate correctly the pressure losses of a  simple T-piece. For the specific fitting that I used, very simple, Revit should revert to the SR5-5 table, but by default it goes to the SR5-1 table, no problem and even though I shouldn't, I edit the loss calculation method and change it to SR5-5. I pull up the very same table that Revit supposedly uses for the calcs (C:\Program Files (x86)\Common Files\Autodesk Shared\Revit Shared\Ashrae) and do the calc by hand and find the branch loss coef. to be 6,31. Sounds about right, it is a terrible take-off. Now, when I look at Revit's calc. it does not even come close. I get 0Pa losses on the branch and and error loss (as if the coeff. value fell outside of the table's data), -93952.19 Pa.
Can anyone form Revit's MEP department please explain why this is happening. Considering what Revit costs, it should be as close to error proof as possible.....
HVAC-Novice
Forget about the whole ASHRAE stuff. the ASHRAE fittings often have nothing to do with what a contractor actually uses. and the implementation in Revit isn't great either. Revit did a better job with Pipe fittings, IMHO.
I ended up putting the SMACNA calcs into my fittings
Revit version: R2025.4
juan_escabiasAUZ5J
Observer
Observer
Thank you HVAC-novice. I will look into your older threads.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
