problems in the design phase offset of cable tray
I am writing to ask you information about revit mep. We are in the design phase of an electrical system and found some problems with the design of the cable tray. Traced the path of cable tray , you can with the offset command to create an equal on the same level, but we can not create one in a plane perpendicular to it. We have tried, as an alternative, the copy command, but besides being a very costly in terms of time (we think), is not going to automatically recreate the curves and junctions various cable tray. There is a way to be able to create offset of cable tray  on planes perpendicular to it?
thank you for the attention you devote to my post
Matteo Rigato
dzanta
do you mean something simliar to this:
see image
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Good evening! Thanks for your answer help.
Actually I meant this (see attachments).
Annex "sketch" I tried to do a hand sketch about the result I would get. I managed to draw two parallel cable tray simply by offsetting the cable tray B, thus creating the cable tray C.
I could not draw the case of the cable tray A perpendicular to B (see attached "section").
Thank you!!
Matteo
dzanta
as far as I understand, this cannot be created automatically via pick/offset method.  I have had to draw them one at a time.
ok! thank you very much for helping! Good day
