i designed the ducts in a imported acis file. I created some level with the view plan.
In the video you see that i go to the view plan and the acis file will not be cutted at the right elevation (i see the window on the roof)
The i go in 3d view setted on the plan view and the building is right cutted.
There is any solution?
BIM Manager - HVAC and Plumbing designer ___________________________________________________________________________
Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums.
You can check visual settings on linked file (if linked file is set like a revit type)
-visual/graphic overrides ->Revit links->Display settings -> check view range to set as hosted view
Other solution can be different view range set to plan levels.If view range is set to unlimited you will see all attached elements.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Any imported 3d files that are not a RFA/RVT extension will not crop properly.
The solution is to add the the 3D "CAD" file into a family. Make it a generic category.
Load that family into the project and the far clip offset should work.
