problem with missing arch elements
Hi
I have a problem with missing architectural elements.
I'm working on MEP part with linked arch model.
In arch model have placed drains with lines (not family or mass or some element , just lines)
When i go to MEP file i cant see this lines.... I check all VG settings.
Please help me .
www.TechRoom.bg
If i understand right your problem you can try this steps:
1.Go to your project
2.VG->linked files->Revit links -> Click to edit Display settings -> Than choose linked view -> and select floor plan.
This will show you view from arch file without using you visual settings like view range and style.
This manual settings is setup for every single floor.
My advice is to use it only temporary for checking arch element and than to switch back to host view.
I hope this will work for you.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Yes this works .
