Plumbing in Revit - Fixture Unit to Flow Conversion
- Mute
- Permalink
- Report
Hi all, hope you're doing well;
as an HVACR BIM Engineer I have pretty much never used plumbing discipline until several of days ago.
recently as I didn't have much to do in terms of projects I wanted to go ahead and learn some plumbing. well, I went through the IPC documents, that Revit turned out to be strictly dedicated to, and figured Revit converts FU to Flow using the table below in the picture (the right one, that begins with 5FU).
I approached this rather arrogantly in the beginning and I thought I would come up with such a workaround that can be used to do not only automatic pipe sizing (without Dynamo involved) but also pressure loss calculations, therefore pump sizing. I failed horribly. the workaround I came up with needed another workarounds which also needed another workarounds some of which affects the first workaround in this sentence 😁
I've never felt more desperate in my professional life than Revit Plumbing discipline made me feel.
Is there any hope? or should I just give up?
TL;DR : Dear Autodesk, please let us do FU to Flow conversion.
