Plenum Box Family supporting a Tap
Sujan.Maharjan
Message 1 of 9
Sujan.Maharjan
Is there any way to modify where I could place a Tap fitting just like In actual System Duct family?
"Revit Lies in the tension between what we want to do and what can be done!"
Replies (8)
Message 2 of 9
RobDraw
You could use a duct instead of the plenum family and cap the ends.
Rob
Message 3 of 9
Sujan.Maharjan
I need to show Panel Filter as well and Internal insulation line properly. Can you suggest me in this family?
And how do I connect Duct Accessories directly If I use Duct as Plenum Box
Message 4 of 9
Sujan.Maharjan
And I don't think a Tap connects to a duct fitting?
Message 5 of 9
RobDraw
Sorry, you only mentioned specifying the location of "a" tap off of a plenum. My solution will work in a number of applications. I took the simplest, most obvious, approach with the given information.
Good luck with your family. I'll be watching this thread to see how it shakes out.
Rob
Message 6 of 9
Sujan.Maharjan
Here's One of scenario of what I'm looking for. Can you please suggest how should I approach this?
Message 7 of 9
RobDraw
That's much clearer but there is still not enough information, but I will tell you how I would approach it.
I'm primarily HVAC and rarely need complex plenum like that. I make a mechanical equipment family. When it needs adjustments, I edit the family .
Rob
Message 8 of 9
ppesquera
I gotta ask, What's your approach to adding a "round" takeoff on top of a rectangular duct? you'd think it would just be easy as attaching one via the elevation view right?
Message 9 of 9
RobDraw
It is and if you want the best input you should start a new thread.
Rob
