Plan Region View Depth affected by overall View Range
Radish_G
Radish_G
Hi Community,
Recently I came across the following problem, hope some of you can help me to fix this.
The problem is the Plan Region view depth affected while I adjust the overall View Range View Depth.
In my model I got two room's where the Room-2 floor is lover 2m from the Room-1. So in order to show the low-level services in the Room-2, I created a plan region and set the Primary Range Bottom to -2m and it works well.
But I want to show those low-level services in Room-1 as well but it should be in hidden line.
So I adjust the overall view range View Depth to -2m. Unfortunately, the overall view range affects the Plan Region settings. I believe this might not be the application issue, maybe the logic issue might be my understanding is wrong.
If you guys got the answer to this issue kindly advice me.
I attached two images to get more clarity of this issue, kindly have a glance.
Also, I attached a sample project as well.
Regards
Radish G
Replies (10)
HEETESHC
Hi @Radish_G
I hope you doing well.
As per your mention issue detail, you want to show domestic cold water pipe on Room-1. But DCW pipe is not on Low Level for Room 1 it's actually on below level for Room-1. For Room 2 pipe is low level. I think this is a logical solution to your issue. Still, you don't understand then we can discuss this on call.
Thanks.
Radish_G
Hi @HEETESHC ,
Thanks for your reply.
Yes, I knew that the pipe is on the lower level. and we have to show it in the Basement-1 drawing.
Due to the requirement from our site team, we need to show the Basement-1 pipe in this level.
My understanding is Plan Region is the one override the View Range but in my case the other way around.
That's why I want to understand where it's going wrong.
Attached Image-3 shows, the final output that I am expecting.
Regards
Radish G
HEETESHC
Hi @Radish_G
I got it.
You need to use two plan region with different view range. also, you need to override pipe in in Room-1 as Hidden line.
Then you got your solution.
Find attached Revit file for your reference.
Radish_G
Hi @HEETESHC ,
You are correct, the view shown in Image-3 is achieved based on the additional plan region. Actually, I didn't override the pipe, line type in the Room-1. I achieved it by adjusting the View depth in the Room-1 plan region, refer to attached Image-4. Actually, what I want to know is why the plan region is affected by the overall view range. I just want to correct my understanding. What I know is, plan region is used to override the overall view range, am I correct? If not let me know why I am wrong.
Regards
Radish G
HEETESHC
Dear @Radish_G,
Hi @HEETESHC ,
You are correct, the view shown in Image-3 is achieved based on the additional plan region. Actually, I didn't override the pipe, line type in the Room-1. I achieved it by adjusting the View depth in the Room-1 plan region, refer to attached Image-4. Actually, what I want to know is (1). why the plan region is affected by the overall view range. I just want to correct my understanding. What I know is, plan region is used to override the overall view range, (2). am I correct? If not let me know why I am wrong.
(1). Ans - Plan Region is not affected by overall view range. Plan region view range & Floor Plan View Range is totally different. We use the plan region to change the view range in a particular area of all floor.
(2). Ans - You can say that but be clear with knowledge about Plan Region as I mentioned above.
fabiosato
For MEP disciplines, the Plan Regions does not work very well, causing a lot of trouble, regarding the visibility of fittings, specially.
Whenever I need to do that I create two views, one for the larger area with a masking region, and another that covers the masking region area and place them one above the other in the Sheet.
Fรกbio Sato
Radish_G
Hi @HEETESHC ,
Can you please explain more on the following underlined statement.
[ (1). Ans - Plan Region is not affected by overall view range. Plan region view range & Floor Plan View Range is totally different. We use the plan region to change the view range in a particular area of all floor. ]
Regards
Radish G
HEETESHC
Hi @Radish_G ,
I wanted to check back and see if you still need help, or if the information provided solved your issue.
Please use the "Accept Solution" button if the solution solved your issue, or reply back to let us know if you still need help.
Radish_G
Hi @HEETESHC ,
Yes, I need clarification on this.
I am quite confused.
Regards
Radish G
HEETESHC
Hi @Radish_G
Can you please tell me, which point made you confuse?
Do you understand the solution?
