I have a pump Family with clearance modeled as semi-transparent solid. It looks nice before I connect it to a piping system. After that the clearance turns to opaque solid.
Is there a way to keep the pump as solid and clearance as semi-transparent?
Thank you.
Solved by dmiller_SCE. Go to Solution.
Don't say I didn't try to warn you about problems associated with using system graphic overrides.
