- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
So I have been tasked creating a piping system. I have never used MEP tools in Revit before.
The problem I am having is I have a vertical pipe which I have pinned in a certain location. it then connects to a horizontal pipe a distance away with a perpendicular horizontal pipe (can be at angle) creating a tee.
My question is, if for some reason either the vertical or the horizontal (not the perpendicular horizontal pipe) moves it disconnects the perpendicular pipe at one of the ends . If I try unpin the vertical pipe it moves the vertical pipe to. How can I keep the vertical pipe in place while moving the Tee piece to another location. or vice versa keep tee in place and move the vertical, all the while keeping the perpendicular pipe automatically connected at both ends
My current work around is to manually reconnect the pipe to resolve. This is OK for a one off case but if you have to reconnect a lot of pipes the are affected by a change, or if there are multiple pipe moves in a project life cycle it can be a time consuming tedious exercise. Surely there must by a way to keep the end locked to the fittings when the system has been revised for whatever reason
and related but if the horizontal (not the perpendicular) is rotated/sloped.
¡Resuelto! Ir a solución.
