Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Pipe Riser Colors Not Showing in Reflected Ceiling Plan View, But Appear in Floor Plan Views
dennyssefelix_visionarch
Observer
Observer
Observer
Observer
I'm experiencing an issue in Revit where the pipe riser colors are not showing up when I create a reflected ceiling plan view, but they appear correctly in floor plan views. This issue only seems to affect vertical pipes; horizontal pipes and other pipe fittings appear correctly. I've checked the view range settings for the ceiling plan view, and they seem to be correct. Has anyone encountered a similar issue with pipe risers, or does anyone have any suggestions on how to troubleshoot this problem?
iainsavage
What method are you using to apply colour and fill to the pipes and fittings?
Ahmed.Elmahdy
Actually if you are using Color Fill it can be placed only in a floor plan or section. You can use another method like making filters.
iainsavage
Again:
Observer
Observer
I assigned a material to each piping system
iainsavage
I'm getting the same results.
The vertical pipes don't take colour in the RCP (on the other two pipes it is the fittings which are coloured, not the vertical pipe segments).
I haven't used material overrides much for colouring so I'll leave this for someone else to respond to further.
