I have a device which functions like a vacuum pump, it has sockets to connect pipe into.
The sockets I modelled as pipe connectors with flow going in, and diameter of connector 1-1/16". (See img1).
The pipe segment I'm trying to connect to it has an OD of 1-1/16" as well. (See img2).
When adding the pipe, Revit is automatically adding a reduction (See img3).
Apparently it is using the nominal size (3/4"), to pick a reducer, when IMHO it should use the real OD diameter of the pipe.
Or does this issue have anything to do with the direction of the flow of the connector?
How can I get Revit to not add a reducer between the connector and the pipe?
