PIPE INVERT NOTATION
Does anyone know of a method to label pipe invert in plan?
You can either :-
  1. Create a Pipe Tag reading the Invert Elevation of the pipe. However this shows the distance between the Z=0 plane and the pipe's relative position not the elevation in relation to Above Sea Level. Unfortunately ADSK didn't allow the Project/Shared option you have with levels.
  2. Use the spot elevation tool and make sure the family type is set to Shared or Relative, depending on what you want to show.
