Pipe Fitting Rotation
So I've looked through the other posts on this subject matter and they don't seem to deal with the issue I'm wrestling with. But basically what I'm trying to figure out is how I can more freely rotate pipe fittings and the modelling of them seems to always want to think of them on a flat plane.
I have several instances of this, but I'll give a real basic example. I have a Sanitary Sewer line sloped at 1/4" per foot. in that Line I'm added a Long Sweep Wye connector. In this case I'm referring to the out of the box Revit Family, but I've tried downloading other manufacturer's fittings to no avail.
The issue here is that it sloped the fitting along the main pipe, but won't then subsequently let me rotate the fitting to turn the sweep leg of that wye up a bit to allow for the pipe coming in at the perpendicular to simply turn down into it with a 22.5 or a 45 degree elbow. Instead it basically acts like the only angle I could want the pipe fitting rotated to is some orthogonal on (increments of 90degrees) off the plane of the main run of pipe.
This is something that can definitely be done in the field, yet in Revit it acts like you're breaking all the rules. I feel like this is a relatively simple thing, but I spent most of the afternoon googling it and can't seem to find an answer. I have a hard time believing that I'm the first one to come across it.
Anyone else have any ideas?
