pipe family
pipe family
Message 1 of 8
pipe family
I need a site or library I can find there some pipe families and how could I add them to Revit?
Replies (7)
Message 2 of 8
sujanc
Whenever you installed any revit version the pipe will automatically come in system tab as it is a system family, and you can create your own duplicate pipe from the edit type options. But if you need pipe fitting then load the fitting from the below path
"C:\ProgramData\Autodesk\RVT 2020"
Please select "Accept solution" if the information was helpful (This allows other users with the same issues to find it higher in search results), or reply back if you need more help!
Message 3 of 8
RobDraw
When you search the internet for this your going to need to be more specific. Piping systems come in many flavors. The fittings and accessories vary quite a bit.
Rob
Message 4 of 8
I NEED PIPE AND PIPE FITTING FOR SPECIAL SYSTEMS.
WHICH I CAN NOT FIND IN REVIT LIBRARY
Message 5 of 8
sujanc
Can you be a bit specific, which system you are talking about. I am not getting you properly.
Message 6 of 8
RobDraw
You may to have to make them yourself or find what you need from a third party source. If you cannot find anything after you search using specific terms related to the systems that you need and/or the manufacturers of those products, you can come back here and ask   questions that mention what type of systems you are working with.
Rob
Message 7 of 8
i need this pipe family like the image with hub and free tail and i need also it's fittings and accessoriesdesc_3161SP3White.jpgimages (1).jpgimages.jpg
Message 8 of 8
RobDraw
Have you done any searches or checked manufacturers websites for BIM content?
Rob
