Pipe connector issues, Flawed or fixable?
When revising some MEP plumbing fixtures and building new content, I ran into these pipe connector issues:
- Work Plane based: I had no face where I wanted a particular connector (CW rough in out of wall), so I tried the use the work plane option.
- You are forced to choose the reference plane option, since face is always the default option. This is understandable but, then you are forced to choose a work plane, even if one was specifically set up and set current for the task (think waste of time).
- When placed on the work plane, there is no way to align the connector since the align tool can't be used with it. (major bug IMO).
- When a pipe connector is placed on a work plane, any plane, the flip-z normal control doesn't work. The flip-z normal control only works if the connector is face-hosted. (major bug IMO).
- When hovering over a pipe connector, the tooltip indicates that the move action is active. Yet, using a mouse to move a pipe connector only results in rotating the pipe connector, Yet there isn't a way to really control such an angle. (Two bugs IMO: false advertising in move icon and inability to really control position or angle of pipe connector). Only the move command can be used to move a connector.
- There is not ability to change the host of a pipe connector from work plane to face. This means that a well developed connector must be deleted instead of relocated, and then rebuilt. (Big time wast bug IMO).
- The connector accepts no point pick after choosing the workplane. It just goes where it wants to go, even if that point is outside of the view (bug IMO, confusion factor extremely high).
- For face based pipe connectors, I found:
- The connector is always put at the midpoint of the face regardless of how practical that is. I mean you can't have hot and cold water coming into the same point, can you? Yet, they can't be moved after placement because they are locked in place. A CW rough in for a water closet shouldn't go into the middle of the back of the tank, right? The odds of having the sanitary waste outlet in the right location, being face based is near nil. I've looked at the OOTB content and its pitiful. I can understand these restrictions for ductwork but for plumbing it makes no sense.
I've only been working in earnest on MEP content for a week. How have you guys been dealing with it for over 10 years?
The only workaround I've found, perhaps an expert might chime in to agree/disagree, is to build a cylinder (a void) that is positionable and attach the connector to its face. I guess that's why the plumbing fixture connector families were made (as a workaround). I'm really surprised that these pipe connector issues never got fixed though. I'd really rather not need to go to the trouble of either importing the connector families or building unnecessary geometry into plumbing fixtures to control positioning and normals.
