Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi everyone,
I am very much a noob with Revit, please bear with me. I have a central model setup for MEP with a model linked from an architect. The problem I'm having is that I need to turn off the demolition objects in the new work views, and vise versa. I'm sure it's something simple thats being missed somewhere. Thank you in advance for any help. I'm using REVIT 2015, by the way.
Solved by kmfuhrman. Go to Solution.
First thing to check is to make sure the Phasing of the architectural model matches yours in name and phase (Existing, New Construction, etc.). This is located on the Manage tab. Then in the Properties of the view, set the Phasing of the view to New Construction. As long as the demolished objects were set to be demo'd in the New Construction phase, they will not show in your plan. Welcome to Revit!
@NickD22 wrote:
Hi everyone,
Kimberly Fuhrman, LEED AP BD+C
Freelance Architectural Technologist
If his her post helped solve your problem, please select it as a solution for the thread. It helps others to find the answers they're looking for when they have a similar problem. Thanks.
Thanks, Chris!!
