parameter array cercle ?
boutheynamzoughui
boutheynamzoughui
Hello ,
I made a empty extrusion cercle and i maked a radius parameter for her and i locked her to reference plan , then I maked an array for the cercle and i added a parameter for the array cercles ,
The problem is when i change the radius of cercle , the cercle get out from the reference plans ,
How can I lock the cercle to the reference plan when i do the array, and how can i lock the other cercles created by the array to a new reference plan ?
Below you will find pictures for more details ^^)
thanks
L.Maas
You could group the extrusion together with a reference plane and use that to constrain it.
Or create the extrusion in a separate family. Then load that family in the host and array the nested family .
Louis
Please mention Revit version, especially when uploading Revit files.
J.Wehmer
This is my preferred method, gives control, and consistent dimension points that you can align and lock
-Please click accept as solution if this answers your question!
