Message 1 of 24
This a problem that has existed for many years.
When is the MCB Rating Parameter (system Parameter) going to be changed from a Type Parameter to a Instance Parameter?
In the Panelboard families, the Mains parameter is a Type Parameter and is used to differentiate between the different sizes of Main Busses, the MCB Rating which is also a type Parameter is often different that the Mains rating requiring you to make a different type for each combination of these parameters that you are using.
