Panel Schedules for Inverters and UPS Panels
We have created an emergency lighting inverter family under the category Electrical Equipment. If the part type is set to "Panelboard" it works fine and is  able to generate a panel schedule. However, for inverters ( and UPSs) where the output voltage is different from the the input voltage, there is a problem. If the part type is changed to "transformer", there does not seem to be a way to generate or edit a panel schedule (the options are grayed out when the item is selected). If the part type is set back to "Panelboard", the "Secondary Distribution System" parameter goes away.
What is the method for creating a panel or load schedule for a piece of equipment that transforms voltage and has multiple secondary breakers?
Nate
David_Robison
Someone can correct me if I'm wrong, but I don't think you can do exactly what you want.
A workaround would be to use two pieces of electrical equipment, one a transformer and one a panelboard. That will allow you to get the electrical model correct.
Not a great solution, but it should work given the features that currently exist.
You can use two separate families, as suggested above, or you can do what we do for inverters, UPS, and MPZ, and create a shared "Input Voltage" and "Output Voltage" parameter and use those for your tags/schedules/etc.
Revit won't really acknowledge the possibility of a branch panel (or its functional equivalent) also being a transformer.
Thanks for the suggestions. I was afraid this was one of those things that Revit does not do, yet.
I am posting this issue in the Revit Ideas forum. Please go
here and vote it up if this is something you would like Revit to do.
Nate Timmerman
Lighting Designer
Scott_D_
Voted. Smiley Wink
Have you tried nesting a transformer with primary and secondary panels with appropriate voltages in the same family?
Not sure if you can create separate Panel Schedules for panels in the same family or if you can mix voltages.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
