Panel Schedule Totals Zero But Connected Loads in Each Phase are Correct
dstrauserMW3A5
dstrauserMW3A5
I am using Direct Power Connectors to create a bunch of loads to go to a panel. I have input FLA values into the connector and my panel schedule will show the correct phase voltage. However, the Panel Totals are zero. The individual loads show an apparent and true load in VA. These should be summed by the default panel schedule. Any ideas? I've changed family parameters of the direct connection but still can't get any totals to show up. Thanks for your help
fabiosato
One thing is strange about your panel schedule: there is no load classification!
Better check the panel schedule template.
Fábio Sato
dstrauserMW3A5
Yes, I believe that may be part of the issue. However, I am using the default Panel Template and have already tried reloading the template as well as deleting the template and making a new one. Here is another panel in my project with the same template applied and correct load classification. Notably, I am using direct power connections for the panel in question, and these have a load class of "other", but they should still be showing up.
The phase A, B, and C loads are correct VA (15A x 120V) but for some reason are not in totals nor in load classification.
fabiosato
Can you share the model for inspection?
Fábio Sato
