Panel Schedule Template Not Updating?
aschneider1
aschneider1
I have a Panel Schedule Template that started out as a 42 Slot Panel Schedule. After starting to Circuit my Receptacles, I increased the 'number of slots shown' to be 54 in the Template Options.  However, when I update the Panel the Receptacles are circuited to, then continue to circuit more Receptacles to the Panel, I cannot use the 'Move Down' function past 42.  Have I missed a step?  Or can I not do that, since I started circuiting the Receptacles prior to making my changes to the Panel Schedule Template?  Any help is appreciated, thanks!
Adrianna Schneider, LEED AP
AEC Solutions Engineer
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
You just need to re-apply the template to the panel board and then it updates.
It may be worht make a couple of different templates for different sized panel boards.
aschneider1
I figured out the issue.  Although I updated the Panel template, I also needed to add the # of Poles in the actual Panelboard itself.
