Short answer is you cannot bring your Excel spreadsheet into Revit for a panel schedule.
You need to start with an existing Revit Schedule template and modify it to look and work like your Excel spreadsheet. You are limited in what you can do with a panel schedule template and in all likelihood you cannot get the same results as your Excel spreadsheet. Depending on your requirements, it can be complex to get the results your desire on the panel schedules.
I hope that helps,
Doug
Douglas Bowers, AIA, LEED AP
Revit Architecture 2016 Certified Professional
Revit Structure 2016 Certified Professional
Revit MEP 2016 Certified Professional
AutoCAD 2016 Certified Professional
www.dougbowersconsulting.com
blog: http://aectechtalk.wordpress.com
Please use Mark Solutions > Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you!
