Panel Distribution System not appears in the drop down list .
engissamadnan
engissamadnan
I have add new distribution system in the MEP settings , but when am trying to assign it I could not find my distribution system in the drop down list ..
Anybody help.
s.borello
Create another panel family or change the electrical connector to match your dist. system.   If you edit that panel family and click the electrical connector what do you see in its properties?  I am betting the connector doesn't match your dist. system.
engissamadnan
I have tried to do so .. but in-vain ..
when am trying to modify the the connector family distribution system it shows 208V , & after I delete it it shows the same result ...3.jpg4.jpg
mpeperkamp
Hi @engissamadnan
Probably the familiy is now set up as a panalboard. Make a copy of the family and change the part type to switchboard in the family. Now you can probably connect the other distribution systems.
Make sure that the connector information is correct as @s.borello  described.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
engissamadnan
Sorry .. I have applied your suggestion but it still the same ..
mpeperkamp
Hi @engissamadnan
Can you make a test project from your template and in it the panel so we can look at it?
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Ahmed.Elmahdy
as mr. s.borello said, in family editor select the connector make sure System type is: Power - Unbalanced and edit
the
voltage it should work.
