PAINEL SCHEDULE: SUM OF THE LOAD IN VA AND WATTS
PEDROVITOR.PAGLIARIN
I'm having some trouble formulating and for edit a painel shedule for Revit eletrical. Im uploading a print of the screen to be clearly. The question si, how i can use Revit formulas to sum all the load in VA and in Watts, at the end of the table?
 I tried to use this formula:
=SUM(Table.Loads.Power)
but the "=" and the "SUM" are giving some trouble to my formula
Anyone could help?
fabiosato
You can get these values using one of the marked commands.
Fábio Sato
npsconsultingllc
Wouldn't it make more sense to do a single calculated parameter at the bottom of the schedule for VA or Watts instead of having both VA & Watts?
Agree with the above either way. A Calculated parameter with a formula would work and probably have the power factor at the device so that it automatically calculates based on the input Watts & PF.
r63501736
Do you know how to make the formula for this situation? this one didnt work: SUM(Table.Loads.Power)
fabiosato
You have the Total Load parameters from the Electrical Equipment.
Fábio Sato
