Override the HVAC supply duct blue (default) color to magenta
Message 1 of 10
Override the HVAC supply duct blue (default) color to magenta.
Is there a way to override the Revit HVAC supply duct (default) from blue to magenta?
Replies (9)
Message 2 of 10
Secttor
hi @Anonymous
You simply create a new filter for your needs with all your customizations.
Hope it helps.
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Message 3 of 10
Thanks, I forgot that. Yes that correct. It has been so long since i had to do that.
I apologize, for that. I just needed to quick reminder.
Brian
Message 4 of 10
RobDraw
That solution is only per view or view template.
Were you looking for a more global solution?
Rob
Message 5 of 10
I understand it can be setup for only one view template, but I can make my "OWN" company template and override the settings where the choices become standard throughout "MY" Revit templates correct?
Message 6 of 10
RobDraw
If that's what you want, yes. I just wanted to be sure that you didn't want to change the color for every view without having to apply a filter to all of them.
Rob
Message 7 of 10
What is the "global" solution to this problem?
Message 8 of 10
RobDraw
System graphics overrides. They affect every type of component on the system in every view.
Rob
Message 9 of 10
Thank you for the quick response!
Message 10 of 10
brianwclayton1969
Thanks for your assistance.
I figured it out, I could use the override format or create a filter.
Thanks Brian
