- Mute
- Permalink
- Report
In a panelboard family, Even if I link the Connector > Apparent Load to a Shared Parameter (type based value), when that panelboard is used in a project, it does not pass through the static value, it passes through the connected load. I'm looking to create a situation that is like: If connected load is less than X, use X, else use Connected Load. Is it possible to override the connected load of a panelboard so that the panelboard does not "send upstream" the connected load but a substituted load?
(it appears that if I input the desired static load into the connector value itself, that will be used, but I'd like to do an if/then based on a type or instance value)
My other CAD is a Cadillac and I like to Revit to the Max!
