Overlapping
Overlapping
Overlapping
HI,
When i am placing the stations on wall the Symbols are overlapping. i tried to add offset parameter but it is not working.
please advise any solution keeping this in mind that i have received the families from the vendorCapture.PNG
L.Maas
Using offset parameters in the family is what I use.
In this case I made it so that it uses also yes/no parameters so that I can have the symbol left, middle or right.
This is also why I rarely use vendor families. I have complete control how the families should behave.
Louis
Please mention Revit version, especially when uploading Revit files.
s.borello
If you are unsuccessful in getting your annotation offset to work you could always change your annotation scale of your view in question.
