Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit MEP Forum
Option to export schedules greyed out. Cant export schedule?
6 REPLIES 6
6054 Views, 6 Replies
Having issues with exporting schedules? refer to screen shot, option to select schedule is greyed out?
Tags (1)
6 REPLIES 6
ennujozlagam
@Anonymous hello, you are in the wrong view? you should be in your schedule view before you can export. thanks
JerVanK
Try This.
Right clicking on the schedule you want to export in the property browser tab. Then when the pop-up box shows up look for open at the top. Click on open, and now go to the "Export" Report / schedule command. It should be available now.
This solution doesnt work.
Does work.
You have to wait for the schedule view to open and keep it as the current view before going to File > Export > Reports > Schedule.
You could also use DiRoots Sheetlink in their DiRoots One add-on.
BenHolmes999
in reply to: iainsavage
I had the same issues,  as tbh, i never use the in-built Revit option
Right clicking on a schedule doesn't give you the option to export (revit 24)
You can though open it that way which you then need to follow the image below to export wihin Revit
Usually i use Ideate BIMLink to export data as well as DIRoots tools
It was greyed out as i forgot the method but you need to open the schedule you want to export as it is only accessible that way, you cant use it in another view and then browse,
hkittad01
This is the correct solution
