Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Nurse Call connector 'blocks' power circuit tag
dtiemeyer
Advisor Advisor
dtiemeyer
When I put a power-balanced load connector and a nurse call connector into the same nurse call family, when the family is placed in the project environment the power load can be connected to a power panelboard, but the circuit number cannot be tagged. When the tag family is nurse call device tag, and the 'Panel' and 'Circuit' are chosen parameters to display, they will only read the 'Nurse Call Panel and Circuit' info. As soon as the nurse call connector is deleted from the family, then the tag will display the power panel & circuit.  Is there any way to achieve both?  Or to have the tag prefer the power panel and display that information?
(this problem does not exist in families that have data connectors and power connectors in the same family).
My other CAD is a Cadillac and I like to Revit to the Max!
fabiosato
Have you tried to place the electrical connector before placing the nurse call one?
Usually, Revit can tag only one connector.
Fábio Sato
dtiemeyer
Thank you @fabiosato , that seems to have done the trick!
