Nested Family Parameters Questions
gavin_hazlett
Message 1 of 8
gavin_hazlett
Parameters of a nested family are unable to be linked and edited inside a parent family.
Accepted solutions (3)
Replies (7)
Message 2 of 8
RobDraw
Yes they are if you make them “Shared”.
Rob
Message 3 of 8
evan_grady4
Also when due to the fact that the unshared family is nested. Replace removing the unshared version from the parent family then reuploading the shared version in.
Message 4 of 8
evan_grady4
A clarification: delete the unshared family from the parent family then reupload the shared version
Message 5 of 8
RobDraw
Deleting is unnecessary. Just edit and reload.
Rob
Message 6 of 8
mtokarzPM4M7
I am having a similar issue. Rvt24
I have a nested family (Fascia Profile) in a parent family (Canopy). I have a parameter in the fascia family called Fascia Height. It is a shared parameter and an instance parameter.
when I nest it in the canopy family I can't associate it to the canopy family and I don't see it in the list of instance parameters when I click on the family.
I have a shared parameter called Fascia Height in the host family but it is not associated to the nested one and I don't see how I can do that as there isn't the = button available.
Message 7 of 8
evan_grady
Can you share your family files because I need to see the way they are being setup in more detail.
Message 8 of 8
mtokarzPM4M7
Here are the two families
