Did hundreds of plumbing and sewage plans, but even after switching to Revit continued to do them in Autocad. Now trying to go full Revit and a couple of things keep tripping me up.
I don't know how it's done in the States, but in my part of the world water pipes are, generally, run in the walls, hot and cold water one above the other. The wall is chiseled(?), and the pipes placed inside. Like this:
As a result our plans for plumbing are quite schematic. We just draw the pipes in space, next to each other. Like this:
I watched tutorials, I know how to draw pipes, set routing preferences... But actually getting a decent plan is a huge chore. I either have to place new fixtures moved away from walls, or place connectors and move them away, to get the pipes drawn outside of walls.
I also tried placing them inside walls. But since I have to draw them next to each other this creates all sorts of clashes, naturally.
So my first question is what would be the correct workflow to get, either plans to look the way they are done here, or to place pipes as they are actually placed but have them somehow both display?
My second question is regarding graphical display of pipes. As you can se in screenshot above, the pipes above "overshadows" those below with a white "halo", any way to remove it?
EDIT: set "Show hidden lines" in view properties to none.
Also, as seen below, in hidden view fixtures hide pipes. Why, how to fix? Do you create plumbing plans in wireframe?
Fourth question is about tagging. If the pipe is of the same diameter we often tag the length of the entire "stretch" of the pipe, no matter how many fixtures are on it (see the 240cm hot one and 490cm cold one on screenshot bellow). As far as I can tell this can't be done with a tag in Revit, right?
Last question is about piping systems. If I never plan on using automatic routing that Revit comes up with (because it's 100% useless) I don't even have to bother with creating systems, correct?
Oh, and one final question to European colleagues, do you use Revit for pressure drop calculation or do you do it outside of Revit, how ever you did it before? We have to use Joseph Brix method, but as far as I can tell that's not possible in Revit.
