Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Method/Resources for Learning to create advanced MEP families
sreaKUEAL
sreaKUEAL
Hi guys,
I have some interest in learning to create my own advanced Revit Families for pipe content, and was wondering if anyone out in the community has any advice on where or who I might be able to contact to find some reliable training for learning to create my own content, the right way.
robert2JCCH
Training is a tricky one. Most coursework for family creation is generic, whereas MEP fittings/accessories often care about modelling orientation in Family Editor for proper interaction with the Revit MEP network tools. Because of this, the people that would know the most would be manufacturers of pipe fitting/accessory content, but they aren't necessarily in the market to train.
If you haven't taken the steps below, they are a good starting point:
  1. Check the Revit out-of-the-box families. Geometrically they get pretty close. More importantly they'll give you an understanding on the directions connectors need to point to properly design elbow/tee/wye families to be compatible with MEP design.
  2. Check manufacturer valve families on BIM repositories, and compare their methodologies to #1. Try them in a project as well to see if they work as intended.
  3. Watch some Autodesk University presentations on pipe design. Not necessarily for the family modelling aspect (very few get into that), but to get a sense on how different industry members actually *use* the families versus how you or your company does. This helps check against personal bias, and opens you up to understanding other use cases that you can then account for in your own family creation process.
sreaKUEAL
I did manage to find some content online, but your right, not many people provide training for it.
Thanks for the advice!
