Message
Message
Message
Could someone help me with this error message, I just put in my serial number credentials and this error message popped up. Could someone help me with this issue?
robert.klempau
Hello @Anonymous,
I found this in a post on the forum:
Need to do this to fix the problem:
Create or set a new registry DWORD value, named ProtectionPolicy, value 1, to enable local backup of the MasterKey instead of requiring a RWDC in the following registry subkey:
HKEY_LOCAL_MACHINE\Software\Microsoft\Cryptography\Protect\Providers\df9d8cd0-1501-11d1-8c7a-00c04fc297eb
1. Hit Windows + R
2. Type regedit and hit enter
3. Navigate to HKEY_LOCAL_MACHINE\Software\Microsoft\Cryptography\Protect\Providers\df9d8cd0-1501-11d1-8c7a-00c04fc297eb
4. In the folder, right click and hit New > DWORD (32 Bit) Value
5. Name it 'ProtectionPolicy'
6. Right click 'Protection Policy'
7. Hit Modify and change the value to 1 and select Base: Hexadecimal
Hope this helps.
See: Error on Setup
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Robert,
     This did not help the situation the "Default External Servers Not Available" screen is still opening when I open Revit. Do you have another solution?
robert.klempau
Hello @Anonymous,
You may not like this one but maybe it will help if you do a complete clean uninstall and install.
Please have a look at these links:
System requirements:
System requirements ‘Autodesk Building Design Suite’:
Install and Uninstall:
These links helped many people already.
Hope this helps you too.
please let me know.
Kind regards,
Robert Klempau
Cadac Group AEC BV
Robert,
     Thanks for the help I really appreciate it.
