Maximum amount of point elements adaptive family?
m-de-lange
m-de-lange
As the title states, i'm wondering if an adaptive family can have a certain limit of point elements?
I made one with 7 points which worked fine.
Then made another exactly the same with 15 points and it doesn't work at all.
roxana_vatrici
Autodesk Support
Autodesk Support
Hello @m-de-lange ,
Thank you for using Revit forum!
The number of the points should not stop the adaptive family to work properly.
Can you please check the family if the points are in the proper order as you are using when loaded into Revit project?
Have a good day!
Roxana Vatrici
m-de-lange
I found the problem and have fixed it succesfully now.
I didn't have 3D snapping turned on, somehow the lines will not being locked to the points. Therefor the family didn't work.
Now i drew the lines with 3D snapping turned on, the extrusion automatically connects itself to the points and the family works without issues.
