@RobDraw wrote:IMVHO, if you want to be successful in your Revit carrier, you should use the right tool for the job. This use of worksets is akin to layers in Autocad. There is no real intelligence to that property when used for visibility. Filters offer a selection visibility properties be applied, not just on or off, and are the right tool for the job because controlling visibility and graphics is what they do.
I get what you're saying about the worksets and layers comparison. I hated worksets so much when I was first introduced to Revit in 2008. I also agree that the main purpose for filters is to turn off or change VG of elements.
@RobDraw wrote:
To me, when it is a well documented best practice to not use them in this way. It is usually a good idea to explore other options to control visibility. If you really want to use them in this way, nothing logical I can say will prevent you from doing it.
I've seen in almost every good practices sections not to do so, just like you say. What I would like to know is where does this comes from? Is it just that people from the industry decided that worksets shouldn't be used that way. If so, fair enough. That's what I am trying to find out. If you could point to some documentation that explains the reasons why it shouldn't be used that way, I would be more then happy to take a look at it and finally understand the reasoning behind it.
Hopefully I don't sound like a d***, English isn't my native language, I am not being sarcastic, just trying to understand where this good practice comes from 🙂
Thanks for taking the time to exchange with me!
Maxime Sanschagrin
BIM Director
Pageau Morel
