Making new centram model to Hvac
kevin_peter
kevin_peter
I am going to make a new central model to Hvac.
For that i will insert the Architural moedl as linked model.
MY QUESTION is: can i strat the new project with none template?
Can someone help me?
You could, but that would mean that you have no predefined settings whatsoever.
This means no level heads, no section heads, no preset dimensions, no systems, no mechanical settings...
You will bump into a lot of issues working with the model as you have no predefined settings. This will take extra work and thus extra hours to make it into the right settings displaying the right way according to your company standard.
You will want to use a predefined template if you have one available. It'll save you a lot of time.
kevin_peter
 u are completely right. i am faceing that problem now.
I dnt ve any level heads and elevation.
whatelse will become problem in the future?
No predefined systems
No predefined view templates
No predefined filters
No predefined Mechanical & Electrical settings
No predefined dimension settings
No predefined annotation settings, like lines
No standard tags whatsoever
No standard generic families for ducting/pipes/cable trays and routing preferences
No company set DWG export mapping
No set materials, so you'll have to make what you'll need
Basicly you're making a new template alongside a project. This works okay if you've got time on your hands and need to make a company template. It'll help you define the standard which your company uses. However, this is considered more advanced stuff since you're bound to come accross things I've not even mentioned above. But in the end it'll help you understand Revit far better, if you've got the time.
Basicly you'll not run into any "problems" as long as you can find the solutions for them and have the time to apply them.
kevin_peter
Thanks lot.it helped me
