Make a schedule of a item from MEPcontent and then export the scedule to excel
i'm having trouble making a schedule in my revit project to get all the correct data into the schedule.
i wanna insert some info of a few components into my schedule like Procescode, Article Type and Code but when i make the scedule i don't get all the correct data and can't find out whats is going wrong.
in the picture below you can see the data of 1 component i want in the schedule. The procescode under the defenition Identity Data is a shared parameter i made to define individual components in the project, but when i make a schedule and select the parameter it is just all blank cells.
as you can see in the picture i filled in the Code and the Procestype in the properties of the component but they dont show up in the schedule
hope i made it clear enough what i am trying to accomplish and what is maybe going wrong.
thanks in advance
Replies (18)
Are the MEP components included in the categories for your schedule?
Jeroen_Sturme
Not in the picture i added but i already tried it with adding the MEP content schedule catagory but nothing changed
That was by the way me, diffrent account.
Did you make sure to add it under this dialog box for your instance parameter?
Jeroen_Sturme
The Catagorie: MEP Fabrication Ductwork and MEP Fabrication Hangers where unchecked. i've changed it and checked it by trying to make a new schedule but it did not work
Is the Procescode a project or shared parameter?
Jeroen_Sturme
Its a Project parameter and the tag i created to tag the code is a shared parameter
Could you send a screenshot of the schedule properties and the parameter associated with the Procescode?
Jeroen_Sturme
sure
Jeroen_Sturme
Jeroen_Sturme
last one
@Jeroen_Sturme wrote:
#2
And the MEP categories are checked under the parameters properties dialog box. 3rd photo attached in this thread "Parameter properties"
Jeroen_Sturme
Yes they are all checked
I just looked back through the OP and see that the item you have listed is a detail item and not an actual family. I am not sure this information will show up in this type of schedule. Have not dealt with this type before. Sorry to have made you go through all these steps.
Jeroen_Sturme
Not a problem at all, im glad some one is even trying to help me out here even if we can't figure out whats going wrong.
i have thought about that to that that is maybe a problem, ive went into the familie and made a parameter inside the Family Types of one of the famillies i numbered and did a test with filling some of the sensors in but that also didn't work so im kinda out of idea's what to try next.
Just one more question, was detail items checked in your parameter properties?
Jeroen_Sturme
yes sir it is checked to
The reason this is not showing up is because it is a detail item placed on a drafting view.
It is a viable way to make schematics in Revit, but unfortunately won't show up in the schedules.
Schedules will only count families placed in the model.
