Looking for free online course about Revit MEP and BIM
gaurang_panchal2CYJS
is there any free online course in Revit mep & BIM related
if yes please share link
[The subject line of this post has been edited for clarity by Community Manager. Original: Re: Forums for Revit Interoperability]
Accepted solutions (3)
SabinaK4RXQ
I have used all the Autodesk materials available and that has helped me a lot until now. These materials were mini courses, AU classes, Help and this forum (which is in my opinion THE BEST because here I get the solutions for problems that are hard to find/impossible to find elsewhere and I get them very fast).
Here are some links below that might be helpful:
Help: https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-195C2C6C-5E2C-422E-A44D-FB3FDFDE276A
AU Classes: https://www.autodesk.com/autodesk-university/search?query=Revit+MEP
On Demand Learning: https://www.autodesk.com/learn/ondemand/curated/mep-fabrication-detailing-in-revit?us_oa=dotcom-us&u...
I hope you will benefit from these resources as much as I do.
curtisridenour
There are also several Revit courses with videos, transcripts, and downloadable content created by @ewing and @Paul_F_Aubin on LinkedIn Learning. You will need a Premium account to access them (which you can get a free trial of). Also, if you live in the US and have a library card, you can get free access to LinkedIn Learning.
HVAC-Novice
Work through this book:
https://www.amazon.com/Commercial-Design-Using-Autodesk-Revit/dp/163057581X/ref=sr_1_3?crid=3K6CN5JF...
Subscribe to BalkanArchitect or similar on YT.
Work on projects and google for help as needed. After research, ask questions here.
If you only do courses, chances are you don't know what part of the course is important, or how to apply it to your specific methods.
Most important, throw away all you do in AutoCAD and be open to do things the Revit way. Number one problem for Revit beginners is to try to use Revit in an AutoCAD way.
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
mari.shimode
Hi @gaurang_panchal2CYJS, did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future. Thank you.
Mari Shimode
mari.shimode
Hi @gaurang_panchal2CYJS, since everyone's replies are useful to the community too, I have marked them as an accepted solution so others who have the same question can refer to it.
Mari Shimode
