Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi, My name is Paulina.
I am developing an electrical project in LOD350. The client asked me add to the model conduit fittings like (UNION). I need to know if this type of fittings correspond to LOD 350 or LOD400 or upper.
Thank you very much for any answer.
Solved by L.Maas. Go to Solution.
With LOD I always will discuss with the client. My experience is that many people have different interpretations/expectations of the different LOD levels. This is because there is not a real LOD standard. Original LOD definition was really vague.
Therefore I often use the document from BIMForum. The nice thing is they have described lots of components including pictures which helps in discussions with different parties. See page 187 of the PDF (LOD 2021).
Louis
Please mention Revit version, especially when uploading Revit files.
Hi!
Form my knowledge for LOD350 or LOD400 you can the normal conduit fitting without material depends upon client. If your apply the material and the data for the conduit it will be useful for LOD500 while your doing it.
As of now I am doing the same for my project to reduce my work in LOD500 with the client notice.
If this solution is OK , please ACCEPT SOLUTION. If your having further doubts let us know
Thanks and Regards,
JAIGANESH GV
He encontrado esta información útil
https://www.scribd.com/document/651876504/Niveles-de-Desarrollo-BIM-LOD#
