Hi All,
I'm trying to figure out what the difference is between linking to the Consumed Folder on BIM360 vs the Shared Folder.
This is how I understand it so far:
- if you want to control how a project is linked, updated and shared, you can do one of 3 methods.
- Live Linking
- Shared Packages
- Consumed Packages
- Also, you can publish models to 360.
- Shared packages are uploaded to the Shared Folder location on the cloud, once you create the package and share it.
- Consumed models are uploaded to the Consumed Folder location on the cloud, once you consume a package that has been shared.
if the project is using the Consumed method, and I have access to the Shared Folder, does it matter if I link my backgrounds to the Shared folder instead of the Consumed folder? Or is it only dependent of the folder permissions that the team lead gives the other collaborators?
We are linked to the shared folder instead of consumed. If they have a chance to have different backgrounds than each other, then we should reload from the right location (which will lose all our room tags). But, if there is no difference, we will leave them linked as is.
Does that make sense?
Thanks all!
