Linking Multiple .DWG Files in Revit AT ONE TIME
I have dozens of huge .DWG files that I need to link to a Revit file (actually same situation for many Revit files). I do not want them hard pathed (not relative, not absolute). I would like NO PATH which is an option for reference files in AutoCAD. In AutoCAD it's so easy to use the PROJECTNAME system variable and then set the path(s) using the OPTIONS command (Project Files Locations). I can't figure out how to do this in Revit.
Also, I'd like to select the entire LONG list of .DWG files that I want linked into Revit (with all same parameters, levels, etc) and then load them all at once. It's making me pick each .DWG file one at a time which is taking forever. If I could just select them all and choose LINK (all), I wouldn't have to sit there for hours clicking away. Same goes when the file locations change and I have to relink/repath them. It's making me do it one file at a time which takes forever. There's got to be a better way to do this. Same goes for IMPORT CAD files which I don't use as often as LINKing.
Thanks in advance for any help.
Kimmy
