Lines missing from 2D export
tmccar
Advisor Advisor
tmccar
When exporting a view or elevation (which is in "hidden line" mode) to 2D Autocad format, some of the lines are missing (e.g. at a pipe elbow, the outside rad will be missing). It results in a lot of manual editing to fix in Autocad.are very faint..
jeremytammik
Sorry, I posted a reply assuming this was the Revit API discussion forum. I only noticed later that it is the Revit MEP forum.
Please excuse the spam.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
RobDraw
I hope the other people over there are more welcoming than you were in that post.
Rob
fabiosato
I have already had the same problem, deleting the fitting and recreating it using TRIM command solved the problem.
Not the best solution, I know....
Fábio Sato
