Lighting Schedule - Lights in multiple spaces
Liam.StamptonM7K4E
Observer Observer
Liam.StamptonM7K4E
Observer
Observer
Im trying to create a lighting schedule that shows all the spaces the lights are located in. This works fine when a light is only in one space but when a light is in multiple spaces Revit doesn't know which space to populate the schedule with so it leaves it blank.
Ideally I want the lighting schedule to show all the spaces the the light fitting is in.
If you see the attached image you can see that the space name for the linear light and downlight is empty because it is in multiple spaces
hmunsell
that is unfortunately how Revit works. we have the same issue in other types of schedules too. the only way to see each room/space is to itemize every instance and show each instance separate.
you can try making a Space schedule then pick the Embedded Schedule tab and embed a Lighting Fixture schedule with Image and Family in it. it may not look exactly the same, but the information should be accurate.
Howard Munsell
Liam.StamptonM7K4E
Observer
Observer
Thanks Howard,
I'll give that a try
stever66
You can also sort by fixture type, and then sort by space name or space number.
Then you will get a separate row for each fixture and each space combination.
fabiosato
You can add space information using the field in the image below.
Fábio Sato
