Light fixture load - for circuit sizing vs. lighting power density
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have light fixtures and assigned the electrical connector to account the load to "spaces". This is for meeting energy code and my understanding is we need to use Watt (real power) and this also would contribute to cooling load (Let's ignore cooling load for now). Energy code refers to W/ft² (and NOT VA/ft²) and light fixture spec sheets refer to Watts (not VA).
For sizing the circuit we need to use Amps and use VA (apparent power). VA and W are related to power factor Multiplying VA by the powerfactor. So, in an example of a PF of 0.9 and a 90W light fixture, I would have 100VA. So for circuit sizing I use 100VA, but for energy code, I use 90W.
But in my fixture family I only have Apparent Power and that value is used for space lighting power density. There is the power factor parameter. I tied it to an instant parameter to play with it. But no matter what I set the PF, the space lighting power density stays the same. Revit spaces seem to use apparent power (VA) as Watts and ignore PF.
So far i didn't circuit the lights to a panel and just entered the Wattage as VA and my space lighting power density is correct. but now I need to add actual circuits. If I just use the Watt, my circuits may be too small. but if I enter the (higher) apparent power (accounting for PF) my lighting power density is too high.
Power factors aren't very small (0.9 to 0.95). So the difference isn't too large. But it bugs me and in some instance it could lead to wrongly sized circuits.
Has anyone noticed the same? Is that an error in Revit? Am I doing it wrong? Is there a workaround?
I was thinking of using 2 electrical connectors (one for W and lighting in spaces, one for VA and circuiting). But that seems complex and I may connect the wrong connector to the panel.
